LarryDel
Aug 20, 2018Explorer II
Problem after problem then wind coming in slide
Hello We have purchased a new 2019 Class C Forest River Forester. We have lived in it for 3 weeks. We have had problem after problem,f first of all we ordered stainless steel appliances, they put the wrong appliances in our unit. We paid for full body pain and then it seems they put a clear (some sort of plastic) around the front of the motorhome to protect from bugs, stones, etc. Its starting to peel in one spot, we have a Lippert Control Panel in both living room and bedroom and the one in the living room goes out for several hours and then comes back. So if you want to check levels or close slideouts, etc. you are out of luck. We were not able to get our bedroom TV to work, it wasn't the TV but the wiring. Camping World couldn't fix it and so we had no TV for a while, but a kind hearted camper who was an electrician fixed it immediately. We have a "Smart Arm" on the awning and it never ever worked. It has a touch pad as well and it is useless. We had the AC leak inside the other day. Had an RV Tech stop by and he said it was the filter. I also called Forest River and the gentlemen said it was a defective filter. He said remove it and we won't have any other issues. He said they will be sending a new filter when they correct the problem. The wall between the shower wall and bedroom wall is not bolted to (whatever, who knows) When you run your hand against the wall it feels flimsy. Almost like there should have been a stud and it glued or nailed to it. Sorry probably a bad description. We have a broken lock on drawer and broken AC vent on ceiling. Also we have a residential refigerator. It is supposed to be frost free, sometimes the temp goes from 33 to 40, is that supposed to be how it works? We were told it does that to defrost. We had a very windy night and I was awaken by the sound of wind. It seemed to be coming in from the back corner of the bedroom slide. We have had two other RV's and have never heard the wind coming through. Is this a concern? My feeling is if you hear the wind then there could be a possible leak when it rains? This unit has absolutely been a nightmare. It's a shame ----- when you purchase an item at a store and it is defective you can return it, but not with an RV. They build them without any quality control, they are not checked by the dealer and then we the consumer must suffer. My husband is 76 and I am 64. We sold our home after years of planning and decided to full time for a while. We are currently volunteering at a local state park for three months. So far we have had nothing but misery. All we seem to do is argue now. Lesson learned, buy local and never deal with Camping World.....Thanks for listening.....Lou Ann
