- 10forty2ExplorerMy ATS hums slightly, but the Progressive EMS that I wired in makes no noise at all. I would suspect a loose connection first. Not meaning to doubt you, but are you sure its the EMS and not the ATS?
- Please post what PI instructs you to do.
- ScottGNomadI would check the connections and make sure all are still tight.
Mine is 2 y/o and quiet. - suprzExplorer
cavie wrote:
SEND IT BACK. Should not make ANY kind of noise.
Mine is less than a year old and it hums. Not too loud but it's noticeable if you listen for it. Google it and it's a common problem. Some do some don't. But they still work even if they hum and show no codes.
Now, at 10 years old... Cheaper ins to check into it, and maybe replace - cavieExplorerSEND IT BACK. Should not make ANY kind of noise.
About Motorhome Group
38,707 PostsLatest Activity: Feb 28, 2025
