Thunder_Mountai
Nov 29, 2013Explorer II
Question about EZE gutters
My 2007 Endeavor has the dreaded Monaco door leak where water surface tension allows water to follow a path around the door molding and down inside the door.
Last winter I fashioned a gutter using some aluminum channel which works pretty well. I ran across the poly EZE gutter that comes in a 10' roll in black. I've got two questions. First is about the foam backing. I assume that with proper surface prep such as cleaning with alcohol that it sticks well. Second question is about flexibility. Assume that it will bend in an arch around the top of the door.
Thanks in advance for your responses.
