- wtfjrExplorerAnother bump to the top ?
- daverichExplorerPerhaps this means no one uses a bug shield.
On my motor home at the end of a trip I use the garden hose and wash them off. So far that has worked just fine. - wtfjrExplorerLiving in sunny FL, I can't believe that RVers are not protecting their radiator from the Love Bugs that swarm here in the Spring & again in the Fall. They will totally cover the front of your vehicle when they are swarming. You are correct that a hose will remove most of the normal bugs from the front of an RV, but Love Bugs are another story.
- Clay_LExplorerMany (most?) gas motor homes need as much air as they can get when they are working hard as when going up a grade. Bug screens can cut the amount of air by a lot more than many people realize.
I don't use one. - DixiechickExplorerWe don't use one.
- topflite51ExplorerInstead of a bug screen, I use hardware cloth and fasten it inside the grill, catches most of the little critters. Use high pressure water when I return home to clean it off.
- wtfjrExplorerTopflight 51;
Hi
You mention that you use "hardware cloth" as your bug screen.
Is your bug screen the hard metal type or is it the soft plastic type of hardware cloth ?
I bought some of the hard metal type today & really wonder if I bought the right one ?
Thanks !
Bill in FL - topflite51Explorer
wtfjr wrote:
The hard stuff.
Topflight 51;
Hi
Thanks !
Bill in FL - wny_pat1ExplorerI was a plexiglass one on a Allegro Bus w Florida tags at a campground in Erie, Pa a couple weeks back. Nice looking rig.
- Cass_SumrallExplorerI am in south FL & I use hardwire cloth covered with black plastic screen inside the grill. It works great to keep the love bugs out of the radiators.
I just spray it off with a garden hose.
I see no difference in my running water temp using it even with the heat of summer now. Works great for me.
About Motorhome Group
38,705 PostsLatest Activity: Jan 14, 2025
