โJan-01-2022 01:30 PM
โJan-23-2022 05:44 AM
Tvov wrote:
Airtabs are still a thing?? I remember a few threads about those years (decades?) ago, but then all the hubbub faded out.
โJan-23-2022 04:43 AM
โJan-22-2022 05:14 PM
brooksrimes wrote:
We have a 2021 Jayco Greyhawk 29MV, class C.
Attached are links for a Hellwig 7180 rear sway bar, a Supersteer SS451 rear trac bar and rear Sumo springs SSR-130-54. Which would have the greatest benefit in reducing the push/pull from large tractor trailers passing us on the interstates?
https://www.hellwigproducts.com/products/search-by-vehicle/?Year1=2021&Make=Ford&Model=E-450+Super+Duty
https://supersteerparts.com/products/supersteer-ss451-rear-trac-bar-for-ford-e450-2021-v8.html
https://supersteerparts.com/products/rear-sumosprings-solo-kit-for-ford-e350-e450-ssr-130-54.html
โJan-18-2022 02:00 PM
navegator wrote:
If the RV has the air tabs, what is the effect on a towed vehicle in the generated votex, does the toad swerve constantly or does it track true?
Or does the toad venicle need to have the yabs also to mitigate the vortex generated by the RV?
navegator
โJan-18-2022 08:20 AM
Desert Captain wrote:That is "Excellent" advice when towing something with substantial tongue weight.
I usually am towing my 6 X 10' {8'tall} cargo trailer loaded to about 2,600#. To offset the increased tongue weight of the single axle I added AirLift 5,000# air bags which at 50 psi return the tongue to dead level, 16" to the top of the ball per the trailer manufacturers recommendations.
โJan-18-2022 06:55 AM
โJan-17-2022 09:04 PM
ron.dittmer wrote:
Hi Brooks,
Everything available helps to some degree all by itself, Everything in combination will help a lot. It is very hard to say if one upgrade by itself will make enough difference. That is why when there is a handling issue, people like myself create a list in priority. If you want to do one at a time, do it in that order. If like me, just spend $2000 installing the list of items yourself, and make the rig handle as best as possible, as soon as possible.
1) Put in the proper amount of air in your tires, per the load carried during a trip.
7) Get a front wheel alignment with your rig loaded as if on a trip.
5) Replace your rear stabilizer bar with a heavy duty version
6) Replace your front stabilizer bar with a heavy duty version
4) Replace your shock absorbers with heavy duty Bistein RV versions
2) Replace your stock steering Damper with Saf-T-Plus steering
stabilizer.
3) Add a rear trac bar
8)Add Front Sumo Springs
I have no personal experience with Sumo springs or air tabs. They might also help. All I know is that items 1 thru 7 together, are very effective for our particular rig HERE. Not only from passing trucks, but the suspension upgrades also improve handling and control, especially appreciated when driving on curvy mountain and canyon byways. The upgrades keep all six tires better planted on the pavement for improved handling and braking. Regardless of where you are driving, the suspension upgrades also reduce driver fatigue and improve passenger comfort.
It is also worth mentioning that none of the upgrades I had done affected the harshness of ride. Our rig always drove a bit harsh until I did THIS. I understand Koni-FSD RV shocks can also improve the quality of the ride, but they are quite expensive.
โJan-02-2022 10:13 AM
โJan-02-2022 10:09 AM
โJan-02-2022 07:44 AM
โJan-02-2022 06:00 AM
โJan-01-2022 05:02 PM
โJan-01-2022 04:43 PM
Mike134 wrote:
If I see him coming in my mirrors (don't always check them) I move a bit right in my lane and that helps a lot. Lowest cost option out there.
โJan-01-2022 04:42 PM
