dougrainer
Sep 24, 2014Nomad
Wilson123 wrote:
I turned it to DC and it appeared to be cooling though. At least the controls said it was. It's a Royale Model.
There is NO WAY you could tell if it is cooling. The controls do not tell if it is cooling, just what Heat source the refer is ON. As I stated, use LP IF you want the refer to continue cooling at its best in transit. 12 volt will only attempt to maintain the existing refer temp. Doug
38,705 PostsLatest Activity: Jan 14, 2025
