โFeb-10-2014 07:14 AM
โFeb-12-2014 08:43 AM
Mocoondo wrote:
There is a special tool used called a ...wait for it ... a Door Panel Removal Tool to pop the panel off. You will likely damage the fasteners holding it on so you may want to pick some up at your local auto supply store before you dig in to this project.
โFeb-11-2014 05:09 AM
โFeb-10-2014 10:09 AM
โFeb-10-2014 08:07 AM
fltioga898 wrote:
I want to remove the outside mirrors on a 1996 econoline 350. these are the heavy cast mounting base type that bolted thru . I see the upper bolts from the inside but the lower bolt is behind the door panel . does anyone know the way the panels come off so I don't tear something up. thanks
โFeb-10-2014 07:58 AM
