- BrianinMichiganExplorerYep replaced the radiator about 6 years ago. About 8 hours to pull it and about 6 to put it back in. Was able to zip tie the A/C condenser up so as to not break any of the freon lines. it is quite an undertaking. It did come out the front only on mine.
- femailyettiExplorerIt defiantly comes out the front, after removing a ton of stuff in the way that make it work in the P30 chassis
- femailyettiExplorerThis is about removing a radiator from a 1986 Holiday Rambler, P30, Hydrovac brakes, turbo 400 auto trans, power steering, AC, air pumps deleted, coolers in both sides of the brass and copper 3 core side flow radiator. I will post the pictures in my other link about a 1986 Holiday Rambler restoration found at
http://forums.goodsamclub.com/index.cfm/fuseaction/thread/tid/28942500.cfm
From what I can find online, it says you drop down, then out past the cross member after, removing the cooler lines, the fan and shroud, and the coolers mounted on the front. I have found that nothing looks that easy, but will be happy if it is.
It looks like !!Sons of Norway's!! older step sister after a night at the bar right now. From what I can find online a 1990 Georgie boy with a 454 should be about the same thing. Have you changed your radiator yet? - femailyettiExplorerIT is removing a radiator from a 1986 Holiday Rambler, P30, with a 454 carbureted motor, turbo 400. it is around 36 feet from bumper to bumper. It looks like !!sons of Norway's!! picture evil step sister right now. I will add the photos to my restoring a holiday rambler section.
there was some information on another site that said, it drops down after the fan and the coolers are removed, ya want pictures I will get ya some. should start around page 8 or so - BrianinMichiganExplorerYou're starting this up again????? It went 4 pages of rambling before.
- crassterExplorer IIWell if you do it take pictures. :) Then it will forever be here for anybody to view.
- Son_of_NorwayExplorerDon't have pictures, but you're right about what needs to be done. I had a shop here in Denver do it for me. Good luck with the repair.
- wolfe10ExplorerWhat chassis???
About Motorhome Group
38,710 PostsLatest Activity: Mar 12, 2025
