msmith1199
Sep 09, 2013Explorer II
1fastdad wrote:Deano56 wrote:I respectfully disagree with this method of mounting. the steel frame was built to hold the weight of the large heavy TV and will do a good job of holding the new one. I don't beleive the cabinet facia will hold the TV for a long period of time going over rough roads.
I would discard the steel sides and make a bracket to mount a hanging tv mount, then make a wood box around that, or fill in the open area with a nice panel of wood with the bracket coming down through it.
Yeah, I'm not removing the steel bracket. That this is pretty solid especially with the bottom on. Not to mention the plastic trim is designed to fit around the bottom of the bracket along with the speaker from the surround sound system. I was going to try and do some type of storage behind the TV, but I already have storage space I don't use so I'm not going to bother with that. I'll make a hardwood backing to go inside the metal box and then attach the LED TV to that. If I do it right, I may not even need any trim around the TV. I'll have to see how it works out.
