Vt_Rv's avatar
Vt_Rv
Replace existing AC or add 2nd unit in the bedroom
My air conditioner, although blowing cold, isn't cooling enough to keep up with the heat. I have a Coleman unit, not sure if it's 15000 or 13500 but think it's 13500.
I was debating on replacing with a new 15000 then realized that the rear vent in the bedroom is pre wired and vented to add a second AC unit.
Now I'm wondering if I should put in a new unit up front and move the old one to the rear.
Just add a second unit in the bedroom.
Or just replace the front AC.
I'm also wondering if this is a DIY job or if I should have it done. With it being pre wired with a connector and breaker And having it vented into the duct work will both units run off the existing thermostat?
I have 50 amp service so will I be able to run both at the same time and run off the generator? The generator is a 5500 with 50 amp service.
