larry_cad
Jan 23, 2019Explorer II
Bumpyroad wrote:larry cad wrote:Tom/Barb wrote:AllegroD wrote:
The Automatic Transfer Switches, in an RV, are generally generator priority.
ours isn't, if you are running equipment on the get-set, then plug into 50 amp service the 50 amp service will accept the load, and relieve the get-set.
Thus the name, "AUTOMATIC transfer switch"
I thought transfer switches were all "automatic"? the other option is just to move the plug to a different outlet mechanically and is not a transfer switch.
bumpy
No, not true. My son's first motorhome had a manual transfer switch. It had a knob mounted on the outside of the box that you could use to switch between shore and genny power.
38,705 PostsLatest Activity: Jan 22, 2025
