DrewE
Jan 23, 2019Explorer II
larry cad wrote:Bumpyroad wrote:
I thought transfer switches were all "automatic"? the other option is just to move the plug to a different outlet mechanically and is not a transfer switch.
bumpy
No, not true. My son's first motorhome had a manual transfer switch. It had a knob mounted on the outside of the box that you could use to switch between shore and genny power.
Very often transfer switches for backup generators for houses are also manual. It's a normal-ish switch; you flip it in one direction for utility power, and the other direction for generator power, and sometimes there might be a setting in the middle for no power.
For whatever reason, manual transfer switches are not at all common in (modern) RVs.
38,705 PostsLatest Activity: Jan 22, 2025
