supercub
Aug 18, 2015Explorer
Replacing tow vehicles tire rubber valve stems with steel?
I just bought an 09 Ford Escape Hybrid. Went to a tire store today to have the rubber valve stems replaced with steel. They said it can't be done, because the Ford tire pressure sensors are part of the stems and if they repalced them with steel, I wouldn't have sensors any longer. The reason I want to replace them, is I have sensors that screw onto the end of the valve stems, for the motor home tire pressure monitoring system. My understanding is to use steel stems when using sensors. Anyone else run into this problem?
Brian
Brian
