Nov-04-2015 03:33 AM
Nov-04-2015 12:30 PM
rjxj wrote:
/snip/
By the way, how much calculating did you do to figure out that you could run a residential on shore power or annoy people by running it for a week while on generator. /snip/
Nov-04-2015 11:04 AM
dahkota wrote:
Because people typically drive for 4-6 hours and then park for about 72+ hours. The coach would need to be plugged in or the generator would need to be run fairly often. If the fridge uses 150A per day, the generator will need to be run at least 4 hours a day just to keep up, if parked in a dry camping situation.
Nov-04-2015 08:12 AM
Executive wrote:rjxj wrote:
/snip/ but I'm guessing /snip/
THIS ^^^ says it all....:S
Unless and/or until you do your research, don't guess.
That said, we don't boondock very much but we've enjoyed up to a week without external power. We run the genset in the morning while making breakfast and in the evening while watching TV. We've had ours for over a year now and wouldn't go back to a Notsocold ever again.
For those thinking of changing over, HERE are pictures of my installation. I did it myself, in a campground. Took me two days and several trips to the local Home Depot, but it was well worth it....Dennis
Nov-04-2015 07:51 AM
Nov-04-2015 07:27 AM
Nov-04-2015 07:26 AM
rjxj wrote:Just for clarification the refer draw is about 6A average and should not be a MH alternator problem. It might be a trailer problem which tend to have a more restricted TV charging capability of the house battery.
The RV place told him it should be fine. If it's not, the generator will come on and help charge the batteries. With that statement they mean that when it's rolling down the road if the alternator doesnt keep up then the generator will come on automatically.
Nov-04-2015 07:15 AM
Nov-04-2015 07:02 AM
Nov-04-2015 06:38 AM
Nov-04-2015 06:35 AM
Nov-04-2015 06:19 AM
Nov-04-2015 06:17 AM
Nov-04-2015 06:16 AM
ford truck guy wrote:rjxj wrote:
So you are parked where you can plug in all the time?
Why ?? he stated that he has a 2000 watt inverter and 4 batteries ..SO it can stay on during travel... why would he need to plug it in all the time ?
Nov-04-2015 06:12 AM
Nov-04-2015 05:43 AM
