Feb-21-2017 07:10 AM
Mar-02-2017 04:04 AM
BigRabbitMan wrote:Dutch_12078 wrote:BigRabbitMan wrote:Dutch_12078 wrote:B.B.Upch wrote:
OK so I figured out how to get the old ones off & I got the new ones in the mail.
New problem
The old ones have 2 wires (black & white) &
The new onea have 1 black wire.
An suggestions on how to wire them in? Thanks
One of the mounting holes has the ground wire attached to it. Crimp or solder a ring terminal on the coach ground (white) wire and secure it under the ground mounting screw. Or cut the wire loose and connect it directly to the coach ground.
The white or ground wire is not necessarily attached to one of the mounting holes. Mine does NOT. I am in the same process. My old lights have both wires attached to the light itself.
That metal bodied fixture is grounded by the mounting screws when attached to grounded metal surface, just as it is when the ground is on a metal eyelet that the mounting screw passes through on a plastic body. The same method of attaching a ring terminal to the ground wire and putting under the mounting screw will work in either case.
Except that with a foam gasket between the light metal body and the fiberglass coach body, the probability of losing that ground connection is much greater than if the ground wire is soldered or directly attached to the light's metal body. Should the foam soften or shrink over time, the connection relying on a ring terminal being press up against the metal body of the light fixture is asking for early failure.
Mar-01-2017 09:42 PM
New problem
Mar-01-2017 01:09 PM
New problem
Mar-01-2017 08:49 AM
New problem
Mar-01-2017 08:43 AM
New problem
Feb-28-2017 02:50 PM
New problem
Feb-28-2017 02:13 PM
Feb-25-2017 06:34 AM
Feb-24-2017 10:35 AM
B.B.Upch wrote:
Awesome thanks for all the good info. Now that hall know what they are can u please tell me how the heck to get them out lol?
& what I can go back with? & where I can get them? Thanks a ton. Would like to get this done before the rain sunday
Feb-24-2017 07:32 AM
Feb-24-2017 06:24 AM
Feb-24-2017 06:18 AM
Feb-24-2017 06:14 AM
rgatijnet1 wrote:You are quite right regarding a Rivnut. You are also right about the trifold poprivets not leaving behind a threaded nut. However the molly jack nut can be installed using a tool that looks exactly like a wellnut or rivnut tool.
It is similar to a Rivnut but I don't remember seeing a Rivnut that is split. I know there are Rivnuts with a floating nut plate.
Feb-24-2017 05:55 AM
