ron_dittmer
Oct 06, 2020Explorer II
Good tip bobndot.
- Disconnect your house battery
- Remove each electrical connection
- Clean the spade portion with 000 or 0000 steel wool
- Using your breath, blow away any loose steel wool fragments and corrosion dust
- If the mate slips over the spade loosely, gently squeeze it with a pliers so that it slips over the spade with resistance.
The thermal couple might also need a cleaning using the same method.
38,707 PostsLatest Activity: Feb 18, 2025
