MrWizard's avatar
MrWizard
Moderator
Dec 03, 2014
Safari Owners question
where is the fuse for the steps
too many fuses up front..does not appear to be in the rear 12v house panel
something has gotten wet..and the steps are stuck OUT..will not retract
the step light is NOT working..so i'm thinking fuse..not the potted control board..although it could be the motor
i'm not crawling under the RV in the rain to check step power
want to find fuse and verify power available or not
i'm not moving until i can retract the step
either by replacing the fuse
OR
things dry out enough for me to crawl under there and disconnect and tie the step in the retracted position with rope or bungees
