shower stall crack
Buster85
Hi, the shower stall in my 2014 Fleetwood storm 32v has developed a crack and consequently leaks. The insert is made by Duo-Form Plastics. I contacted them and they said it would have to be replaced. Can anyone recommend a repair that can be made, such as a silicone caulk or waterproof adhesive that might work as a stopgap ?? Thanks!
13 REPLIES 13
Buster85
The crack is on the wall, not the pan, and the crack emerges from behind the door frame, and appears to originate from a screw hole.
I haven't taken it apart yet, but it seems that the scenario DutchmenSport presents is what happened - I need to make the screw holes in the wall and floor larger so they can flex. But only after after I drill a hole at each end of the crack to keep it from spreading.
Thanks again!
J-Rooster
downtheroad wrote:
Eternabond Tape....
X-2, might not look good but it will stop the leak. And that's the main thing, you don't want water leaking into your coach as you know.
hilldude
If the shower is fiberglass a place that repairs showers can repair it.Had two bathtubs crack Loews sent sent some one and repaired it.they reinforced it could not tell it had been repaired.Check with lowes or home depot.
noleakman
I had a crack on my shower wall just above the shower pan which leaked and I went to WalMart and got some stick on none slip pads that normally go on the bottom of the shower where you won't slip they looked like a Tuna about 6 inches long cleaned the spot and stuck to wall it has been there for 5 years no leak!
filrupmark
Repair or replace. Make sure you have plywood platform to support from underneath to prevent future damage .
2004 Ford F250 Super Duty 6.0 Diesel, Bilstein 4600 Shocks, 16K B&W Patriot, Michelin M&S
2014 Augusta Flex AF34RS Trailair Tri Glide pinbox,
JT Strong Arms , Bridgestone R250'S, KYB Monotube Gas shocks
Finally a smooth ride !!!
Valkyriebush
I used a smear of JB weld water proof putty. Mashed it up, spread over crack, done. A little discoloration, but ok for us. Easy fix. Going on 3 or 4 years now.
Command Master Chief (AW) USN, (ret)
2003 Fleetwood Excursion 330 Turbo Cat 39D
2000 Jeep GC
2005 Big Ruckus (Rides Behind Jeep)
2003 VTX 1800
DutchmenSport
Is the crack on the shower pan (where you stand), or on the wall (the shower surround)?
Either way, you should drill a small hole at the end of the crack (each end and any other splinter cracks that might have occurred. This will keep the crack from splintering farther.
To repair the best, you should remove, the pan and, like suggested above, apply a fiberglass resin filler (if on the shower pan ... floor) both sides, underneath and on the top. Once dried, sand down to make it smooth.
If on the wall, you need to do the same thing, drill a small hole at each end of the crack to keep it from spreading. Then fill with a resin epoxy, or tape.
If the crack is on the surround (wall), you really need to drill out the screw holes where it attaches to the walls so the surround has room to wiggle. More than likely, when installed, they drilled a small hole in the surround and then inserted a screw and attached to the wall. Bad, bad, bad way of doing it. There is no "give" in the surround. The slightest bit of stress or the slightest temperature changes causing the plastic-fiberglass to expand or shrink at a different rate than the wood behind it, will cause stress on the screw, causing stress on the surround, causing a break. So, make sure the holes drilled in the surround and the shower pan are larger than the screws so there is some wiggle room when the camper flexes or temperatures change.
Buster85
Wow! Great suggestions - thank you all!
chuckftboy
The best way to repair it would be to remove the entire shower insert, add fiberglass resin and mat to reinforce it then fill in the gel coat with a repair kit. Like njtony said, cracks in fiberglass always seem to get worse if not repaired right.
2019 Horizon 42Q Maxum Chassis w/tag
Cummins L-9 450 HP / Allison 3000
2006 Jeep TJ and 2011 Chevy Traverse Tows
okhmbldr
Find a local supplier for acrylic whirlpool tubs. They always have a source to repair the tubs. I've had several repaired, even with large chips missing and cracks. They grind out the crack, and fill with a color matched acrylic, then buff. You can't tell it's been repaired.
Greydennyhawk
An automotive body shop may be able to assist you. This shower stall, I believe is like an epoxy resin/ fiberglass reinforced type of product. We had a sink in our Old Jayco Grayhawk, made by the same firm that had a hairline crack in it and an auto repair guy fixed it for us and matched the color pretty good!
Denny, Rosie and Josie the Beagle
2016 Allegro 36 LA
2016 Mazda 3
downtheroad
Eternabond Tape....
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
njtony
is this not under warranty ? You might try etenbond.but with continued use the crack will just get worse.if like mine coachman, there is very little support under floor.
