Big_Katuna
May 26, 2014Explorer II
SilverLeaf, Check engine light CAT/Freightliner experts
My 2005 Freightliner-CAT C-7 chassis has started giving me CHECK ENGINE light occasionally.
Fleetwood, 50K miles.
It has happened when I stopped suddenly, hit a bump and once when I went around a long off camber corner. All guages read normal and it does go into limp mode.
It always resets if I turn it off a few minutes and today, it went off by itself after 15 minutes or so.
My question is this. My local Diesel house charges $175 to read the codes. Would a SilverLeaf tell me as much as their diags or Freightliners diags will? I would rather put the $175 toward a Silverleaf which I will have down the road. Reading their specs it sounds like it should but real world experience is golden.
Its a weird problem and it is so intermittent I want some knowledge of what is causing it to help chase it down. All my fluid levels are good.
It seems like it is a a wiring issue or a sensor that is affected by vibration or the pitch change.
Thanks for your help.
