Edward_75's avatar
Edward_75
Slide adjust
I need to move my big slide toward the front as it hits door handles when it is going out. It is a power gear and is on a 1999 class a home.It is electric driven. Thanks for any help you can give.
  • Finally figured out what was wrong with slide out. The distance between the slide floor and slide beams was not the same on both ends. After I reset the rear one the slide moved forward enough that it does not hit door handles now.Thanks to all who read my first post and Fred thanks for the reply. Happy motoring to all.
  • Fred, thanks for the reply, I will keep looking as I need to move the slide forward. Thanks again.
  • I've done a lot of adjustments on my Powergear slide, and I do not remember anything that can be done to move the slide toward the front of the coach.
    You can get some documentation from Powergear. Go to
    powergear link
    In their keyword search box, try electric slideout system. You should see two operations manuals. Maybe this will help.
    Fred
