MrWizard's avatar
MrWizard
Moderator
Sep 09, 2022
Slideout stuck in half way position
1997 Bounder 36S
Because of extended extreme heat, a few days back i decided to bring in the slide and reduce the space to be cooled,
But it didnt come all the way in,
its now half way in/out, so now its not weather sealed or bug sealed, the blood suckers have been eating me alive, and we have major rain approaching from hurricane Kay, its hydraulic, when i push the switch for in or out i hear the pump whine but the slide doesn't move, doesnt even "thunk" like hydraulic ram piston & linkage usually does when working,
Maybe the Heat has addled my brain cells, but i havent found the fix for the problem, im guessing that hyd solenoids arent being activated, the slide system and leveling system are separate , i need to get it in so the rv will be rain tight, i don't need or want the high wind driven rain pouring in,
The freaking 2 week triple digit extreme heat interrupted my fuel line replace/repair so i am unable to start the engine, but have two battery chargers, and have always had enough power to easily operate the slide,
What am i missing where do i need to look, can i pull it in with a come along or ratchet strap, push it out some how,
I have a 6 ton hyd body ram/tool/jack
I prefer having it come IN
But OUT is better than stuck half way, i use the word stuck, but its not physically bound as far as i can tell, its not twisted and has clearance on both sides and top , its not stuck in the opening and its not gear driven, its hasn't been leaking hyd fluid,
Control for the solenoids or the pump blowing an internal seal are the only things i can postulate as possible problems, but my thinking might be muddled
