81Midas's avatar
81Midas
Spring loaded rear high level bunk removal help!
Hello all. Here is my first post.On a whim I bought a 1981 Midas Kingston class C.In the rear there is a spring loaded bunk. I removed the actual wooden bunk and the mechanism released and actually punched thru the rear of the coach. Any experience with these things? Now the tension is off the mechanism but Im worried that it may have sideways tension that will pop my windows if I try to remove it.Thanks!
  • You might want to check in the Toy Hauler sub-forums... these types of bunks still exist in some units.
  • The bunk raises to the ceiling and lowers to about chest level. Hope this helps explain. It's spring loaded and attaches to the rear left and right walls of the RV.
