โApr-27-2019 06:36 AM
โApr-27-2019 03:00 PM
โApr-27-2019 12:39 PM
โApr-27-2019 11:45 AM
BFL13 wrote:
Sounds like it is just a bad battery connection, like others suggest. Clean posts and clamps, try again.
When the starter went bad on my E350, it just whirred. Was the "Bendix" not engaging. New starter solved that. Needed a tow from campground to a garage nearby though. (Thanks, Good Sam!)
โApr-27-2019 11:31 AM
Gjac wrote:
I would start by cleaning the battery terminals. How soon after taking your 11 year old battery of the charger did you take a reading and get 13.5 v? That could be just a surface charge if you took the reading an hr after you charged it. At any rate if you don't want to buy a new battery I would charge all 3 let them sit over night take a reading on each one and if you see 12.6 v on two of them wire them in parallel and see if the engine will turn over. Once you know your connections are free of corrosion and you have enough CCA's to turn the engine over(if you have house batteries which are good you can use your emergency start button also) and it still wont start the next step it tom look at the starting relay. See if you are reading 12+ v on each side of the relay. Try all that and let us know how you make out.
โApr-27-2019 10:42 AM
โApr-27-2019 08:25 AM
โApr-27-2019 08:20 AM
โApr-27-2019 07:39 AM
โApr-27-2019 06:57 AM
