Fleetwood Couple wrote:
dougrainer wrote:
SIMPLE test for power to Kwikee steps. Turn Chassis engine ON. Open and close the entry door. Watch the under step amber light. IF it goes on and OFF when opening and closing door the power to the step is correct. Then HIT the motor with a hammer(engine running) while opening and closing the door. IF the motor has a dead spot, it will eventually start to operate. If so, the motor is bad. Replace it. Doug
Thank you Sir,
This procedure worked on the third smack of the motor. Time to order a motor.
I just replaced the motor in mine a few months ago. Mine quit after just 5 years use (2012 model - see signature). Smacking it didn't help, but since it wouldn't move at all, I immediately suspected the motor, so I disconnected it and verified via a continuity test, that the motor had shorted out internally and was dead. Soo, just ordered a new motor and put it in.
Not a hard job, but definitely takes some patience, getting that motor positioned right, and getting all the bolts in place, with all the right spacers, etc. I'd plan on this taking you a good couple of hours, at least.
