Escapade's avatar
Escapade
Suburban SF35 Will not come on
Suburban LP heater was only blowing air. Removed it and cleaned out dirt dauber nests. Re installed and it would not come on. Removed again and checked all wire connections, LP gas connection, and fuse. Tried it again and still does not come on. We have a rear heater and it works fine.
What am I missing? Could it be a bad circuit panel? The unit is 10 years old.
1 Reply
  • Did the blower work while out of the rig and on the bench? (I use my car battery to test in that situation.)
    If so, the problem is likely in the coach wiring not the furnace.
