goufgators's avatar
goufgators
Televisions don't work...need advice
Both t.v.'s quit working at the same time. Appeared to me to be a tripped circuit breaker. So, I looked and no breaker was visually tripped. Just in case, I opened and reclosed all the breakers but t.v.'s still off. They are the only things off...all other electrical areas work. I can't see where each of the two t.v.'s are 'plugged in'. The one in the front is the type that comes up out of the counter. The one in the bedroom is apparently plugged in inside the wall area. In short, can't locate receptacles. I hope one of you readers can clue me in to a possible problem - location - (fix). Short of that...as much as I hesitate... back to CW.
