pacearrow95's avatar
pacearrow95
temperature
Hi
I have a 95 pace arrow 460 ford, ford chassis ,My gage reads NORMAL,
Im trying to find what are the degrees for each letter. Also my gage is running on the right side on the M, Just got out of the shop Im on the road right now, new radiator 6 months ago, just had put in the last couple of days. new clutch fan, new water pump, new thermostat,
was running between the O & R .but started creeping higher, had clutch fan put in couldnt get 10 miles down the road till hit the L , So had water pump put in and thermostat ,was running on the R now on the far side of the M, doesn't go higher if I drop down to 55 miles cools down some, sitting at a truck stop now in Amarillo TX heading to AZ ,
  • Just a thought. Does your transmission lines run into your radiator and back to the transmission like normal vehicles? If so you might want to try and buy a transmission external cooler. I have been reading a lot on this site about heat and engines. Most of if not all the people on here who have been experiencing high temps are due to the transmission. They all put on 1 or 2 external trans coolers and problem was solved. Just my 2 cents.
  • UltraGauge
    So you have an OBDii port? If so then this gauge will tell you the exact temperature.
    I have one and it works quite well.
  • Between the M and A should be around 190 - 195 but the gauge doesn't have numbers because it ain't that accurate.
  • have so been thru the warm temp thing, but ours has downright blown the cap off the cooler liquid reservoir. steam and coolant everywhere. replaced the water pump, temp sensor, thermostat, radiator, radiator cap, lots of tubes, pipes, belts, clutch fan and shroud. still warm. findlays in las vegas told us we needed to replace the engine and gave us a quote. figured it had a crack somewhere in the block, but they couldn't find it and didn't show up on their wonderful, sophisticated computerized gizmo--which they felt was wrong. my husband felt the instrument panel didn't show us a correct temp. upon starting it almost immediately went to 260--but after replacing the radiator didn't blow the reservoir cap or boil over. he had them install an engine temp gauge. this little puppy is showing it at between 218-224 at which time the clutch fan is now engaging and reducing the temp. i thought the temp was still somewhat warm. his research seems to indicate a temp somewhere around 218 could be considered normal for our engine, a chevy workhorse w22. since your gauge is rather nebulous, i wonder if a separate engine gauge would tell you the real story. my DH says it's the best money he's spent.
