- bukhrnExplorer IIIIn my case, it's the door seals they're cheap & they suck, going to replace them.
- YosemitebobrExplorerMine leaked too, until I ran a bead of silicon all around the point of contact of the basement attachment points and I ran another bead on the inside - no more leak. In rain the tires threw the water right up to the underside of your motorhome right where the basement units are attached. They have foam, but it's a hit or miss, and usually a miss with the foam being in the right place when they attach them. Mine have been that way for a year now and no leaks. I drive to Washington a lot from California, so lots of rain.
- glenns4dExplorerThe unit leaks in the rain when it is parked or when I spray water above the compartment but not on to the compartment. I have put additional moulding all around the door but water still gets in.
- DrewEExplorer IIIs this a leak from above (i.e. when parked in the rain) or from underneath (when driving in the rain)?
I need to go around and reseal mine from underneath. I don't know if they have always been a little leaky, or if it's simply that the 17 year old sealant etc. is rather past its prime. I kind of suspect the latter. It looks to me like a little bit of surface prep and some quality time with a caulking gun would go a long ways to improving things. - ronfishermanModeratorYou may need to put additional rubber seal around door edge. To stop water leaks I had to put an additional layer of rubber (not foam) around door seals.
- dnhillExplorerI have had storage compartment leaks that occurred when driving in rain. The compartments are supposed to be sealed, but several of mine were not (35SK).
About Motorhome Group
38,707 PostsLatest Activity: Feb 28, 2025
