- BobGedExplorer
6string wrote:
The bedroom has a step up in the back. All carpeted, no hatches, no screws, nothing visible. Hoping someone has had to get to the engine.
Jim, I received your PM and just emailed you instructions on how to remove the hatch cover. I also included instructions and part number for replacing your coalescing filter, which if it hasn't been previously done, is long overdue.
Good luck, and keep us posted on how it goes. - haddy1ExplorerIn addition to the hatch that others have described, you probably have a smaller one in the closet in the back corner next to the washer/dryer wall. At least my 2012 36QSH has both.
If you first remove the panel under the closet you will get an idea of where the sides of the hatch are located. That should help you find the screws. If your carpet has been replaced, all bets are off. - WAFlowersExplorerMultiple square-drive screws hidden in the carpet on top of the step-up between the bed and the rear closet. Expect six or more screws. Then it is likely stuck and will need a prybar to lift (the first time).
- BobGedExplorer
If you can send me a private message with your email address I'll send you a PDF file with pictures and instructions on how to remove the engine access cover.
On edit: The file will be for your carpeted model coach like I had in my 2009 coach, and not my 2017 with a tile floor.- rolliejesseExplorer
I can see where the panel is because the carpet is cut there but can’t get it to pull out
there is no handle and if I put a small hook down the crack it still won’t pull out any thing i am missing
thank you for any help you can give me
- want-a-beExplorerWe have a 2013 Phaeton with the step up in the back. I took a magnet to find the screws holding the floor down, the screws on ours where square headed, also had to remove a panel in front of our closet! Hope this helps! Good Luck
- 6stringExplorerThe bedroom has a step up in the back. All carpeted, no hatches, no screws, nothing visible. Hoping someone has had to get to the engine.
- JohnG3Explorer IIOur Allegro Bus has a 3x3 hatch in the bathroom. With the floor tile and framing it has to weigh near or over 250 pounds.
- azdryheatExplorerLift up the floor
About Motorhome Group
38,707 PostsLatest Activity: Feb 13, 2025
