flteng
Jun 05, 2013Explorer
Tire question
This is my first time replacing tires on a DP and I am a bit confused. I have Goodyear 295/80R22.5 on my DP. They are original with 05 date code. They still look good, no sidewall cracking, well over 9/32 tread, 35K miles. Looking to replace as I read in this forum that after 7 years they should be replaced no matter how good they look. The local tire shop is recommending Hankook AL11 on the front and AH24 rear. My concern is load rating on the front axle. My coach manual says 14600lbs @ 115 psi. The AL11 is rated 6610 lbs @120psi. Also the Hankook size is 295/75R22.5. Should I be concerned about the slight size difference and load rating.
