Old-Biscuit
Aug 11, 2014Explorer III
Artum Snowbird wrote:
I think what you are doing with the laser gun is perfect. Also, you can shoot your brakes and your center wheel bearings too.
Those guns will also find hot spots in your wiring if you are troubled by intermittent connections and don't know where to look, loose wires tend to heat up the connections so your laser gun will find that. Check your battery connections too, and connections to grounds.
X2.
Simple, easy to use 'tool'
