Ivylog
Aug 12, 2014Explorer III
I temp mine on the sidewall one inch from the tread as this is the easiest place to temp the inside rear dual tire. I've seen as much as it being 10 degrees hotter than the outside tire. On a hot day the most I've seen is 125 on the inside tires. With a good cross wind you can have a 10 degree difference side to side and this is the reason I run 5 psi higher in all my tires over what the load chart says to.
