ahfox
Dec 27, 2016Explorer
Trail lite BPlus winterization woes!!!!
I recently purchased a Trail Lite BPlus 2004 motor home. I did not get a r-vision motor home manual with it and thanks to the kind souls on this forum I was able to download a manual, but probably not for my year? For example, it says to winterize, you can drain the system and fresh water tank by" going to low point drains located under (?) the motor home They will be labeled to show correct position(handles turn one way to open, the other way to close"
There are NO valves under this motor home! Under one cabinet by sink is labeled "low point drain" and another on the dinette seat that houses the fiberglass fresh water tank. In these corners are pop up valves with key ring pulls and the one by the fresh water tank and pump is another small turn valve attached to what looks like a outlet from tank. I have opened all valves and it still appears that the water tank contains about 6" of water. When I hold flash lite up to opaque tank, it looks like a undulating shadow(I assume to be liquid water) moving when I rock the motor home. I am in upstate NY(Ticonderoga) and I have been keeping a Polonis ceramic heater on since freezing weather hit. Am I missing something with these drains??? I did open all sink handles and even used air on the city water inlet but I am bewildered on why the fresh water tank is not draining. Any help will be greatly appreciated!
