- SCVJeffExplorerI don't worry about the Travler since the footprint is huge. But the the arm is being forced into the roof by the weight of the arm, and the arm tensioning spring once the reflector is stowed all delivered to that wheel. It'd be interesting to measure that force. Anyone got a fish scale?
- cat199ExplorerI have one on my 2007 bounder diesel. No reforcement plate was needed, I did buy the small plate for the roller to roll on. Been on for 2 years no problems, and no problems with the operation. I would spend the money again for it.
- ezgoinExplorerMy installer originally didn't plan on adding a roller plate on my rubber roof, but I insisted on one based on Winegards recommendation. (I even emailed Winegard to confirm its use, and showed him the email.) The plate is only about 4" x 4", much smaller than I had envisioned. But, it's there, and I feel more comfortable with it there.
- Bill_SatelliteExplorer II
SCVJeff wrote:
fpresto wrote:
That arm pushes pretty hard on the roof and the intent is to spread the load out. I Dicor'd a SS plate on the roof that's 4"x10"
Rather than add a landing pad for the roller when the dish is stowed I just added a strip of EternaBond. Works great.
That's actually not the intent. The intent is to simply prevent the minimal side to side movement while stowed from causing damage to the rubber membrane. In most cases a strip of Eternabond would accomplish that without issue.
The guideline for a landing plate is EPDM rubber type roof and not roof structure. Having said that, if you had a roof structure that concerns you enough to make you think you need a landing plate you should probably install the entire thin roof mounting plate. Putting additional protection under the wheel is never a bad thing, just unnecessary in most non-rubber roof installations. - SCVJeffExplorer
Rather than add a landing pad for the roller when the dish is stowed I just added a strip of EternaBond. Works great. - CA_TravelerExplorer IIIUsed Dicor on my rigs and for my sons solar panel wiring. Click here.
- Bill_SatelliteExplorer IIAs mentioned above, the Genie works just like at home in an RV with the SWM3 Trav'ler. It's pretty easy to explain.....It's the exact same antenna you have at home, just made mobile!
I have the Genie plus an H25 instead of a client. It's a belt and suspenders approach in case my Genie were to die I could move the H25 and at least watch 1 channel until I got my Genie fixed. The good news is that I have had the Genie in the RV for over a year without a single issue. - allbrandautoExplorerso for a fiberglass roof just drill a entry hole than every few feet use dicor in a mound to secure cables to roof
allbrandauto wrote:
For fiberglass or aluminum roofs use Dicor to secure the wires every few feet along the roof and where they enter.
wow did you drill thru roof for cables - CA_TravelerExplorer III
ezgoin wrote:
For the client - C41 or C41W?
I'm not Bill.Satellite, but I just had a new Trav'ler installed and my Genie (HR-44) and a Genie client for the BR both work perfectly when moved from the house the MH. No set-up issues at all. Plug 'em in watch TV.
Do you have to configure the remotes for the different TV types?
38,705 PostsLatest Activity: Jan 22, 2025
