To replace older heavy TV sets held in front center cabinet by cable operated lifting device. The cable lifting crank device hole is in the adjacent right cabinet in top rt part small rt front cabinet Use 5/8" socket on 6" extention. Crank the tv out with somebody to help remove or keep it from falling out. I believe the old 27"TV weighs 80#. Replace with 32" flat screen. You can view mouting options on you tube. Good luck
Probably applies to most THOR older rv's
