Bikeboy57
Nov 06, 2023Explorer
I dont know anything about your coach. You should have a supply tank, that is separate from the primary and secondary brake tanks. If you pull from the supply side, you already have the benefit of the existing PPV
You should be able to use the same air feed that is used for the rest of the leveling system
38,709 PostsLatest Activity: Mar 09, 2025
