Dog_Trainer's avatar
Dog_Trainer
Valve lash Set again
I just set the valve lash on my B5.9 Cummins. It takes about an hour after I get everything opened up to access the motor. Cummins recommends every 24,00 on my old mechanical B motor. It was more like 45,000 for me on this adjustment. So just a reminder to check you manual and set the Valves at the proper intervals. BTW as in the past very little adjustment needed on mine but I tweaked them a bit nothing out more than .002 from factory specs. Now off to the rest of the spring cleaning and getting ready. I am taking the stripes off this year and I think I will paint them on.
  • Yup, came on Caterpillar engines-- initial adjustment around 30,000 miles. Then every 100,000.
    I do mine a little more frequently-- like them right to specs.
  • Good job on getting it done. Had mine done here at home, right around 25k miles, and they were very close. I'm at 55k now, so I should still be good for a while.
