onrecess
Sep 09, 2020Explorer
Water damage **** floor
I have water damage to my floor. 2005 Georgie Boy Pursuit.
So, I pull apart the sponge that used to be particle board. I saw repair on the web. But the floor is ONLY particle board (OSB). Under that is a plastic fabric. That is ALL. No insulation, nothing. The floor is screwed to angle underneath.
Question: I cannot see any way to keep the plastic fabric from getting shredded when I cut out the OSB. I guess I'll just glue/tape up the surrounding fabric, and put 6mm plastic sheet (visqueen?) under the new plywood and overlapping the fabric a few inches. I'm going to seal the ply with epoxy. Does that sound right? Is there another way?
