polish_texan
Jun 26, 2017Explorer
Water research for RVs
Hello Im a grad student from Lamar University doing research on water. I wanted to know how water is used in RVs of all sizes. Refilling, disposal, cost and problems if any!
Best!
MB
Best!
MB
polish_texan wrote:
Another question I have is that does the water storage/carrying issue prevent people from traveling to certain areas? Like because of the cost of carrying a lot of water or proximity to a camp site determine where you can go?
polish_texan wrote:jplante4 wrote:
Most travel trailers, fifth wheel campers and motor homes have a fresh water tank and a "city water" hookup. If you pull into a campground site that has water available at the site, most people use that water through the city water hookup for at least washing and bathing. Most campers will use bottled or filter campground water for drinking and cooking. Some people install an in-line particulate filter on the campground water.
Carrying water in the fresh water tank is expensive. At 8 pounds per gallon, that's 600-800 pounds that you need to haul up hills etc, so most people in the above group just put a small amount or water in the tank to use for flushing the toilet on the road.
I would say 60-70 percent of people RVing use water in this manner.
The rest fill their fresh water tank and stay at sites that have no city water available. These campers are very cognizant of their water usage, and have adopted habits to make the amount of on-board water last as much as 2 weeks.
Thank you jplante4! So a lot of what you said is what I was wondering about and you cleared it up. A few RV owners Ive spoken to in person also said they only drink bottled water instead of campground water.
RLS7201 wrote:
I can't help myself. What do you polish? Cars, furniture, RVs, air planes, etc. Or could it be your of the same heritage as my European born wife? But that would be with a capital "P". GRIN
do widzenia
Richard
wa8yxm wrote:
There are different answers, I will try to give a few
Myself
I bring park (City or well) water in via a home made activated charcoal filter. This (And the filter floos) take care of most of the bad stuff in the water. (But not all) Water for drinking and ice making is then run through a PUR filer in the fridge.
Water for dish washing, Showering, Toilets, Other cleaning is not additionally filtered.
Fresh water storage is sanatized occasionally by adding bleach 1/4 cup er 15 gallons, and then rinsing with baking soda and water and then clear water.
Some folks. Only drink bottled water.. Some folks do not filter.
Waste (Disposal) Excess fresh Well I no longer have that issue but back when I8 did Dumnp on well drained ground. Very few restrictions on dumping fresh water
"Used" water is divided into 3 categories
Black This is from the toilets
Gray Other waste (non toilet) INCLUDING the Kitchen sink
Wash Other Waste NOT including toilets or the kitchen sink
Regulations vary but in some places WASH can be dumped on the grass.. IN a much smaller number of places Gray can too but I don't.
Black ALWAYS goes into a sewer system (or a pump out truck from Porta-potties-R-Us) No place allows you to dump black on the ground.
How to dump:
Many (Most I suspect) use what we call a "Stinky Slinky" it is a 3" hose specifically designed for the job. Fast, Efficent. but some don't like dealing with it.
Also sometimes you have issues such as a HOLE that sticks up out of the ground (Sewer inlet) so high it's ABOVE your dump connection... So. I also have a macerator pump. this is a 12 volt electric pump that feeds a common 3/4 inch hose coupling,, that in terns goes to a far Distant (up to 50' in my case) or elevated hole in the ground.
Treating the tank with chemicals... I do not, Many do. Found the only real advantage to the chemicals is to the seller's profit figures.
