sandv
Aug 24, 2020Explorer
Water Valve leaking - Help!
Hello All,
I have a 2002 Coachmen Pathfinder Sport which is new to me and I'm working on a water leak in the freshwater system. The leak occurs whenever I pressurize the system, and I've tracked it to the lower valve in the exterior water panel. The only interior access to this valve is through a small access panel in the sidewall of the bathtub, behind the toilet. Just enough access to reach around an touch it with one finger, but not to work on it.
When I found the leak I thought there must be a way to get to this valve by removing the panel from the exterior of the vehicle, but it doesn't appear to be the case. Reaching from below would require the removal of the black water tank - yikes!
I frankly can't believe that they built this without any means to service these very important valves. Surely there must be a repair option that I am overlooking.
Any suggestions would be GREATLY appreciated - thanks!
