Jim_Arndt
May 18, 2013Explorer
What to check prior to buying a 1999 E-Superduty
I'm considering making an offer on a 1999 Itasca 29b on the E-Superduty chassis with 39k miles. Anything I should check prior to the offer, and what, and should I plan for as far as maintenance. The current owner has only done oil changes, tires and batteries, so I would expect it's due for some major scheduled service since its been 13 years. I'd also like to use this information, to justify why the coach doesn't deem high blue book price the buyer is asking for:
- flush and replace coolant
- transmission fluid
- Differential oil
- Check/replace brakes (this depends on the driver but how long typically do the brakes last?) Any
- Replace Spark plugs (Is this a good idea? Only 39k miles but has been 13 years. With the spark plug thread issue, is it better to replace now or just run them until 100k? I was thinking replace now, to minimize the chance of a plug breaking when removed. Any school of thought on this, should I run while I can?)
- Should any other ignition components be replaced?
- Other?
After having a Fleetwood, I was surprised to see the quality of the Winnebago fiberglass roof. I did lightly step on the left side of the cab over, it deflected about 3/4 inch at the seam between the cab over and roof. This was a concern, but there didn't appear to be any rot, seemed like what ever fasterners they used failed. I'll have to take a closer look from inside, anyone seen this before?
Also all interior and carpet is original, but in decent shape for it's age.
Thanks, any thoughts on what I'm getting into or expect in terms of maintenance and cost is appreciated.
- Differential oil
- Other?
