Jim_Arndt
May 21, 2013Explorer
Thanks everybody for your responses, I'm not sure if I should run away from this coach or take my chances with a low price. He's in Finance and believes his price is good,and I'm not the best negotiator, the Finance guy at the Car dealerships somehow always get me to buy the $500 dealer installed alarm... I'll explain what I found and offer a price and see if he takes it (or I may walk based on the opinions I get here. Here is what I found today:
1. Leak at ceiling AC, owner stated it was last year and he had it resealed. I saw no signs of rot, but the ceiling stain was 2x4 feet, I may be able to clean this somewhat.
2. Roof to Cab Over joint is failing on left side (I'm going to create a separate post on this item to see if any other Winnebago owners have seen this, as this is my biggest concern. What I found is, at the curtain track for the cab over, there is a 1" wide metal strip that appears to bond the roof to the cabover. It has screws placed every 6 inches or so, screws on the left 12 inches of the track were missing. If I put my hands on the roof and lifted, from the Roof/Cab joint, the roof would raise about 1/2 inch and I could see a gap above both the left side and right side upper cabinets and the ceiling. From on top of the roof, while standing on the roof side, if I reached out and lightly pressed on the cab over it would deflect down about 1/2 inch at the roof/cab seam. There was no rot, it seems what ever holds it together, the mechanical fasteners have failed. There is no leak at the joint, the dicor flexes at the gap. This would be a good area for Eternabond, just don't know how to fix the movement/flexing of the joint.
3. Stripes are cracking badly, looks like a dried up lake bed up close. My wife would like to get into a better looking coach, as our current 1988 spent it's life getting backed in Phoenix. Another item to knock down the price.
4. Brake Pads look new. Owner mentioned the 39k miles was mostly cross country driviving which makes sense, what scares me is he said he didn't downshift down hills as he was afraid of wear and tear on the motor... (He did tell me he has taken it to Mammoth Mountain a lot, I was thinking he may have a lot of pad left but doesn't mean they wern't overheated, glazed and cracked...) Rotor surfaces are moderately rusted as expected, but here in Southern California I would expect the Calipers are ok as we don't get much rust here. If I make an offer, I will test drive and check hub temperatures for a hanging caliper.
5. Manifolds show no signs of cracking, studs I could see looked good.
6. 6 tires replaced, with date code of February 2010 (7th week.) They were not covered, but sidewalls looked good with no checkering.
7. Engine started immediately, and idled perfectly, I was surprised how smooth it ran. Road Test is next if we move forward at this point (owner only had 30 minutes to show it today, so that is next.)
So item 2. above is the big concern. I'd like to understand how the cab is attached to the roof, and if this can easily be strengthened/repaired or if this is major.
I really appreciate everyone's advice, lot's of great info and knowledge on this site.
Thanks,
Jim
Thanks,
Jim
