- ChowanExplorerThanks for the help guys.
- kknowltonExplorer IISome RVs now list the UVW or the CCC (or both) on a sticker on the exterior. Ours does that; no stickers in the cabinets.
- jrpExplorer
Chowan wrote:
Thanks for the explanation. So the big question is where does one find the UVW? Not in the brochure or on line.
Call a Winnie sales person and ask for it, or visit a dealer that has one of these in stock and look for the label inside one of the interior cabinets that lists the UVW and CCC. - usersmanualExplorer
unfortunately you will need to run it empty over the weigh scale
Seems odd no UVW is there but it is what it is
maybe phone them? long shot but who knows ? - ChowanExplorer
jrp wrote:
Chowan wrote:
I am not saying we are going to purchase this rv, but this is what we looked at yesterday.
No matter what we get I need to know and understand how much I can load and pull with any DP.
Winnebago Solei.
GCWR 33,000
GVWR 27,910
GAWR 10,410
GAWR 17,500
So if I a understanding these numbers correctly I have approximately 5900 lb to play with which will have to include my toad?
No, you're not understanding it correctly. You can not calculate "how much you can carry" without knowing the UVW unloaded vehicle weight. From the above you know that the max weight of the motorhome and all its contents & passengers may never exceed 27,910 lbs. Next you need to subtract the UVW. Just to have a number, lets say the UVW is 23,500 lbs. Then using that example, 27910 - 23500 = 4,410 would be your cargo carrying capacity; including all passengers, contents of tanks & all your on board stuff.
Also note that, even if you're under the 27910 with all your stuff loaded, you still must not exceed either the 10410 on the front axle or the 17500 on the rear axle. You may have to shift some contents to keep the overall balance within the axle limits. Depending on the location of your water tank, sometimes traveling with a near full water tank may put you over the front axle limit, even though you're under the overall GVWR.
As far as your allowed towed weight behind the MH, thats 33000 - 27910 = 5090 lbs (or more if you're under the GVWR)
But the hitch on that MH is probably rated for only 5000 lbs. So your real toad limit is 5000
Thanks for the explanation. So the big question is where does one find the UVW? Not in the brochure or on line. - rk911Explorer
Chowan wrote:
J-Rooster wrote:
I did the overall weight in my Winnebago W-22 Chassis one time when I bought it new in 2004. I filled all tanks, except for gray and black tank and I didn't weigh with my toad. And my RV was overweight. I never bothered to weigh it again.
So you drive overloaded? How many of you guys drive over loaded? How many even care? How many don't know? I want to know if I am being over cautious, at the same I don't want to endanger anyone. Never owned an RV before. Thanks for all you help.
I bet a lot of owners would rather not know. me, just the opposite. IMO it is reckless not to know and if known not to take remedial steps. but that's me. - jrpExplorer
Winnebago Solei.
GCWR 33,000
GVWR 27,910
GAWR 10,410
GAWR 17,500
But the hitch on that MH is probably rated for only 5000 lbs. So your real toad limit is 5000 - ChowanExplorer
So you drive overloaded? How many of you guys drive over loaded? How many even care? How many don't know? I want to know if I am being over cautious, at the same I don't want to endanger anyone. Never owned an RV before. Thanks for all you help. - Bill_SatelliteExplorer IIThere are 2 known numbers that cannot be fudged. The carrying capacity of each of the axles and what the scales show each axle is carrying. The difference between capacity and weight is what you have left for loading additional "stuff" into the RV.
The next thing you have to consider is how much of a towed you can tow. This has more to do with the weight of a fully loaded coach plus the weight of the tow vehicle and whether the coach can safely stop the combined weight of the 2 vehicles.
Be sure you buy a coach that will get both of these formulas right or don't buy it! - rk911Explorer
Chowan wrote:
Ok, I know what the gcwr, gvwr, gawr f/r. but where do I find the overall wet weight of a MH so I can figure out how much I can put on board? Thanks for the help.
do not trust the labels you might find inside closets, cupboards, on a salesman's clipboard, etc. the only true way to determine any of the various weights is to weigh the MH at a certified scale. IMO the RV industry has, maybe purposefully, confused the issue of weights. all you really need to know are the
- empty weight: (minimal fuel, no supplies, people, etc. this gives you the base weight of the unit.
- wet weight: full fuel, fresh water and LP tanks. you might consider filling the gray and black tanks, too, to get a 'worst case' number.
- loaded weight: full fuel, fresh water and LP tanks plus food, supplies, clothing, people, pets and other stuff.
of course, you need individual axle weights for all of the above. once you know these weights you will also know how much weight you can safely tow which, in general, will be the lesser of the following:
- the GCWR (gross combination weight rating) of the MH minus the actual weight of the MH as it is loaded for travel (includes fuel, fresh water, food, clothing, people, pets, supplies, etc.)
- the weight rating of your tow bar
- the weight rating of your hitch
good luck.
About Motorhome Group
38,763 PostsLatest Activity: Dec 13, 2025
