โOct-29-2023 06:02 AM
โNov-04-2023 08:37 AM
Blaster Man wrote:
I tried two 12 volts, but that was not enough juice to run the inverter...the third one fixed that.
โNov-04-2023 06:59 AM
โNov-03-2023 11:05 PM
Blaster Man wrote:
Call it what you like, my three 12 volt AGMs do fine on an all electric 45' coach if you do very little dry camping...we do virtually none.
โNov-03-2023 08:08 PM
โNov-03-2023 04:46 PM
โNov-03-2023 03:16 PM
Blaster Man wrote:
One often forgot about fact is that the 12v are very much lighter than the 6 volts. I went from 8 six volts to three 12 volts (all AGM) and my total weight went down a bit over 300 lbs.
โNov-03-2023 04:57 AM
โNov-02-2023 05:17 PM
โOct-30-2023 11:58 PM
pianotuna wrote:
Properly set up is not possible unless you wish to buy a special purpose alternator. Or add a diode type device to the existing alternator.
The computer in the engine "looks" at the starter battery voltage. When the starter battery has recovered--charging is scaled back. Once that happens there is little or no charging of the house bank.
A dc to DC takes the incoming voltage and boosts it to an acceptable voltage for charging the house bank.
My dc to DC charger does a maximum of 20 amps. That works out to less than 5 amps per battery.
Because I have a larger than usual bank, I chose to set the output voltage of the dc to DC at 14.7 volts. Don't do this unless you have researched what the ideal charging voltage is for the house bank.
โOct-30-2023 02:14 PM
โOct-30-2023 04:35 AM
Campinfan wrote:
Thank you all, I am learning a lot. I ways thought my coach batteries recharged as I was towing. That is problem the root of my problem with my current rig. I was draining the batteries too low as I was running the fridge and driving long distances.
โOct-30-2023 04:29 AM
Campinfan wrote:
The reason why I say four of either is because I would have room for 4. That is why I have the question of 4 12 volts which would give me 4 times the amps of one....or 4 6 volts which would effectively give me 2 12 volts. I hope that clears it up. If all things were even....I would have 4 x 12 volts @100 minutes a piece (just pretending here) so that would give me 400. If each 6 volt was 100, I would only have 200 because I know in series only the volts double not the amps but then they would be partially in series so then I would have the equivalent of 2 12 volt batteries @ 100 a piece for a total of 200. So it seems the 12 volt battery is a better idea until I think about how much lower you can drain the 6 volts.
โOct-30-2023 01:42 AM
โOct-29-2023 07:47 PM
Campinfan wrote:
So Pianotuna, are you basically telling me that I could get a DC to DC charger and then that would take the starting (chassis) batteries and use them to charge the house batteries? And of course the alternator would recharge the starting batteries.
