Vacationer04's avatar
Vacationer04
Workhorse brake recall
What years of Workhorse chassis were recalled for the brake caliper problem? Is there a website I can go to check to see if a used MH has had the recall work done before I buy said unit? Or who would I call with the VIN to check that out?
Thanks!
  • And you can go to workhorse.navistar.com and enter your vin to see if was even subject to the recall.
  • Not all chassis were under the recall, mine was not neither was the w-24.
  • Or look under the hood and see if the recall completed sticker was placed on the vehicle. Mine was a yellow WH sticker with the date and recall number written on it.
  • Once you have a VIN number, you can call your local GM dealership, and ask if the work has been done.
    Good luck,
    Fred.
