OFDPOS
Aug 09, 2017Explorer
Yep Another Steering Stabilizer Thread
Well in other posts I had reported about the typical wandering, porpoising and pushed over by semis passing etc.
Started out by replacing the undersized front anti sway bar , then the rear bar.
That helped allot with the swaying and being pushed over, but still had the wandering , thinking the stock shocks even tho only 13K miles,, it is a 2011 MH would definitely help with the porpoising I replaced the shocks front and rear with the Koni's FSD's should have stayed with Bilsteins , but enough of kicking that dead horse subject.
Ordered up the Safe-T-Plus steering stabilizer , at the time best price I could find was from Lazydays RV Accessories & More .
I finally got a chance to install it this morning , first off it is about twice the size of the stock ford not sure what you want to call it ? If its what Ford calls a steering stabilizer helper ? well they still have a lot to learn.
Once off I could easily push it in and pull it out with very little resistance, off to the recycle bin with that.
Wondered why Ford mounts it on the Passenger side and then on the tie rod .
But Safe-T-Plus has you mount it on the drivers side then on the tie rod.
Once I installed it , I tried to line the front tires up as straight as possible , tightened up everything , started it up and turned the steering wheel lock to lock nothing rubbed etc.
Hopefully tomorrow will get a chance to take it out for a test drive and hopefully don't have to adjust it.
Instructions calls for a helper to hold steering wheel while another makes the adjustment as needed. If so then it will have to wait till the weekend.
Over all once again an easy install item. Adjusting if needed, well that will be a wait and see.
Still scratching my head why ford has it mounted off the passenger side and Safe-T-Plus has it mounted off the drivers side, there doesn't appear to be anything that the linkage, brackets or stabilizer would hit/rub.
