big_buford's avatar
big_buford
211z vrs wally
Having a hard time deciding between the 2. The wally has been out for some time now, how is it doing? Thank you.
  • Thank you for the replies, will go with the wally. Remote will definitely help in a toy hauler.
  • I have the 211k to allow me to use the Dish Tailgater when I travel in my rv. The 211k is my at home box I take when I travel. The bad thing is when Dish changed their dish anywhere player software it does not load or play with the 211k. I used to be able to log in to Dish on my computer and watch older tv episodes I missed. I can no longer do this due to their changes.
  • jorbill2or wrote:
    I’ve had both .. get the Wally.
    If you need to convert to a older tv just get a rf converter on the composite outs of the Wally( 10 bucks )
    That's how I send the signal to to the rear master in our coach. RCA to Coax $10 converter. With the Wally RF remote, it works for us.
  • I’ve had both .. get the Wally. The Wally has RF remote ( you can change channels through a wall ) the guide and interface is MUCH better! Similar to the hopper. Scheduling recording of shows is far superior. The Wally actually has the ability to record one and watch another live program at the same time IF you are using a open face 3lnb dish.
    Actually if you add the over the air tuner you can record two over the air channels in addition to the two satellite channels making (4) total Simultaneously, provided you add a hard drive and pay the one time $40 all on account fee of course.
    The initial problems with set up a few years ago appear to have been solved and mine runs much cooler than the 211k or z I’ve had and “works “ faster
  • If you can live with SD in the rear of your RV, the 211K has coaxial SD output. I elected to use the existing coax to the rear of the coach. While the 211K runs a little hotter, it is a better featured device than the 211Z.
    Richard
    Both receivers work very well. The big advantage to the Wally is that is uses RF for the remote so you do not have to have a direct line of sight from the remote to the receiver.
  • Big Katuna wrote:
    I have the Z. I’d get the Wally. The menu is the same as the Hopper. I believe but I might be wrong that the Wally has two tuners and lets you record a show while watching another.
    The K has a built in OTA tuner. Not made anymore. Can buy them used on EBay.
    Check output connections. I only use HDMI.
    The Wally does have 2 tuners but the software only allows the use of the 2nd tuner when connected to a DISH open face antenna with the current DPP LNB.
  • I have the Z. I’d get the Wally. The menu is the same as the Hopper. I believe but I might be wrong that the Wally has two tuners and lets you record a show while watching another.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Feb 08, 2025
