here is the info i normaly givet out.. with a problem like yours
but your 6100 may be EVDO capable
if you find your self connecting at cable modem speeds
400k up
you may want to
use the alternat QNC network, which is painfully slow But is free
verizon says NO tethering ( phone to computer via cable , blue tooth, etc ) ON the EVDO network with out a data plan and will charge big time overcharges or this..
here is the setup info HOW to
Phone(s):
1: LG vx4500
2: LG vx3200
3: QCP Slimlin 860 .. Retired
Provider(s):
verizon wireless
on the phone
navigate to menu- settings - 1xrtt data- port - port speed
set port speed to 230,400
if it is not already there
now select port type "rsc232'
this is also , likely to be already set
now plug the phone into the computer
goto dialup networking
create new connection
choose modem
find your phone under modems
for modem properties uncheck "wait for dial tone"
verzion is your ISP
phone number is #777
ID is your complete 10 digit number at vzw3g,com
111555xxxx@vzw3g.com
PW = vzw
you will be using your minutes if you are NOT on EVDO broadband network
if your phone shows 1xRtt in the phone window you are OK
if it shows EVDO.. better disconnect quick and switch to the QNC network
to use QNC
change ID to QNC
and PW to QNC
I can explain it to you.
1997 F53 Bounder 36s
