- trnflaExplorerI picked up a Duracell PS from walmart and it seems to work fine.
- fcooperExplorerI'm aware you've solved your problem, but this may help someone else, so I'll post it here.
I encountered the same problem on a Toshiba laptop. It was caused by using a non-oem power supply. Replaced power supply brick with a real Toshiba laptop power brick and problem went away.
Fred - MNtundraRetNavigatorThanks for the reply and actual fix.
- trnflaExplorerOkay, finally figured it out. My power supply died and I ordered a replacement from ebay and it was too noisy on the AC that caused the strange issues.
Thought I would share. - trnflaExplorerIt seems to be an issue with the power grounding.
- MNtundraRetNavigatorThe pad on the laptop has settings too, similar to a mouse.
Check the settings. The sensitivity may be too high. Just having the pointer accidently pass over the back arrow may cause the action. - Gonzo42ExplorerYou might try cleaning everything perhaps with alcohol so there are no dirty contancts anywhere. Check connectors, too. Run Ccleaner. I'm still trying to figure out the bizarre jumps I get with Google Maps.
- ventrmanExplorerTry using a Mouse and disabling the Touchpad.
- HappyKayakersExplorer III
trnfla wrote:
MNtundraRet wrote:
Maybe it's time to upgrade to IE11. No problems here.
Some of the critical site I need to access will not not with ie 11.
Not even with Compatibility View? - trnflaExplorer
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,794 PostsLatest Activity: Mar 14, 2025
