MEXICOWANDERER's avatar
Jul 14, 2017
New PC Video Card or Audio Card An Asset?
Nope. I don't know squat about PCs.
My 1990's final PC really needed a video card to shop (chopping?). And an audio card really improved music sound quality.
But I may be getting a desktop.
Are the video and audio cards "buggy whips" for 2017 grade desktop computers? Or is this a "Depends on the motherboard" issue?
I have a beautiful new View Sonic 28" monitor and I would like to take full advantage of it.
Will a video card make images appear sharper?
  • What are the video and sound inputs to the view Sonic, monitor
    Everything now is HDMI
    A new desktop will have good video, but it might not have an RGB or VGA output Port
    You might need a video card , or external Port converter, to go from HDMI to xvga? For the monitor
    Sound? It will have excellent sound range capability
    But an audiophile wanting to listen to Mozart is going to need to improve the speaker system
  • On-board audio-video will be adequate for most needs. In the 1990s there was usually no video capability on the motherboard and audio tended to be limited. Early 2000's Intel and AMD started putting modest 3D video capability into the chipsets that interfaced CPU with memory and peripheral busses (Core family processors in the case of Intel). Around Gen 5 to Gen 7 Core processors, the integrated 3D graphics got moved into the CPU package (in some cases onto the CPU chip), with performance often equivalent to mid-range 3D graphics cards of the late 1990s.
    You won't need an add-on graphics card unless you are into extreme 3D gaming. Add-on audio has all but disappeared at the consumer level, but you can still buy professional grade audio capability, usually as external equipment, if your needs include multi-channel mixing, equalization, and special effects.
    My graphics intensive apps have been the last three versions of MS Flight Simulator. FS8 (2002) and FS9 (2004) ran pretty well on entry-level 2001-vintage GeForce boards, and 2004-vintage Intel GMA graphics. FSX (2006) challenged the best available 3D boards but by 2008 the mid-range chips from AMD and NVidia were adequate for FSX, Intel HD Graphics was still marginal although surpassing anything I could buy for less than $3000 in 1990.
    There are a lot of games even more demanding, partcicularly if you are displaying on multiple 4K monitors, and the graphics card market is aimed here today, where for $600-$800 you can buy capabilities available only from Silicon Graphics (at $30,000 to $100,000) in 1998-2000. I don't think you can even buy add-on graphics below the mid-range today, because that market has been taken over by the graphics on the main processor or in the interface chipsets.
    If you are asking about upgrading a 1990s vintage PC with a new graphics card, I think you'll find that there is nothing much newer that will interface with your motherboard. The high=performance deskside computer I bought in 2001 was still using the AGP interface for graphics, and in 2004 the only AGP cards I could find were not much above entry-level. Most desktops of that era didn't even have the AGP, all the slots were 8-bit PCI.
    Looking at upgrades for desktops with AGP interface, NVidia is still manufacturing 2004-vintage GeForce 6200 chip for upgrade purpose. The chip is a half step up from typical motherboard graphics of that era, reason for upgrade would be to have graphics capable of supporting Windows Vista and Windows 7 (i.e. Direct3D up to version 10). If not going past Windows 2000, there is a $10 AGP card using the (2002 vintage) GeForce 4 chip but that takes support back to Direct3D version 8, Windows NT and 2000.
    For upgrades to HD video (that would give sharper images) there is at least one manufacturer selling a card using ATI Radeon HD3450 chips (2008 vintage), again an entry-level 3D graphics chipset, but better performance than entry level a few years earlier. This graphics chip family supported Direct3D 10.1, so Vista and Windows 7.
    Considering any graphics card upgrade to a AGP slot motherboard, the slot would have to be AGP 2.0 or newer, none of the cards I'm seeing work with AGP 1.0, which had a different power supply voltage from later standards.
  • Even a low end/inexpensive modern desk top would be a MAJOR upgrade from your 1990 computer - typical motherboard has decent/good video/audio on-board chip.
  • wnjj's avatar
    wnjj
    Agree with the others here. Onboard video (in the CPU these days) is plenty good for anything but high end gaming. The best way to get a sharp picture is to make sure you run the video resolution at the monitor's native resolution. Doing otherwise will blur things a little. If you need larger print, turn up the font sizes.
    Onboard audio has been more than adequate for longer than video has.
  • As you have seen video cards get really expensive, and elaborate. 3D graphics is the reason most buy them, and if your not gaming , they really aren't needed.
    Audio? What are you running Windows wise? Unless you still have a Windows 2000 or xp unit, chances are adding good amplified speakers are all that you need. Ok Most any new desktop unit will have graphics that will make your monitor look great. Amplified speakers will sound good but like a home stereo, sound is subjective.
    Get a "name brand" machine, windows 10 and you will think lightning is coming off the box and boards. If you want to get into custom builds you can spend as much as you wish, but for basic web surfing, email, and non specialized use, they are going to be very capable. Myself I have an out of the box e machine upstairs and an Acer down, one with Windows 7 the other upgraded to 10. Neither cost over 300.
  • Ductape wrote:
    Integrated av on today's motherboards is quite capable, unless you're a true audiophile or gamer or otherwise producing a lot of video.
    X2 no need to upgrade unless you have a special application in mind such as gaming or engineering cad drawing
  • Integrated av on today's motherboards is quite capable, unless you're a true audiophile or gamer or otherwise producing a lot of video.
